MCE PUC on BV5
This is a very basic question, but I somehow cannot find the right menu.
I have a computer connected over HDMI->DVI with my BV5 (on DTV). My computer is attached to an MCE receiver, which I assume should be easy to steer via PUC?
Unfortunately, I cannot find the menu where I can set the respective PUC when selected DTV.
Any thoughts and help appreciated!!! Thank.
I think you need to select an other source in the menu I think you will find like "DTV decoder dvi".
Thanks. I am now a step further. Unfortunately, MCE is not part of the PUC list of my BV5. Is MCE not supported?
No probably not, I have never heard about a MCE.
B&o has discontinued the update of the stb ic/eprom. So best thing you can do is to find a "physical" stb that can be controlled by one of the puc in you TV.
