Masterlink vs. cat7
Just delivering Masterlink doesn't need that much. In many cases, I'm sure even CAT5 will do.
But, it has been stressed that the future Beonet - whatever that will be - requires CAT7. I don't think shielding is the decisive factor, it is the general characteristics of the cabling.
So if you want to be future proof and are doing a new install / complete renovation, it would be madness to try and save a little money by installing anything else than CAT7. The price difference is practically zero after you count all the work in.
But if the cables are inside the walls already, I would just try to use it. Replacing anything "just in case" would be equally silly.
Cat5 and cat6 are essentially the same, cat6 is just higher specd, cat6e has shielding but cat7 has each pair individually shielded and is made to even higher spec. Cat7 is the way to go today, but most cat7 cables are thicker, around 8 mm, and much more stiff than their unshielded brothering.
The shield is important, no shield means that the likelihood of interference and hum is much higher, especially with cable runs over 10m.
So I would say buy cat7 and buy Draker or Lapp cable as they are german made high quality cables. They may cost double as the chinese, but are still only a euro or so per meter, so...
Also note if you plan on putting normal connectors on the cable, you need to buy shielded connectors and connectors that can fit the thick cable. Lapp makes some (fm45), but they are hard to find.
Does anyone have a wiring diagram for how to connect masterlink to cat7?
Hi
I have no idea about the German cables you mention but for the purpose at hands: Masterlink or even the future Beonet, whatever it pans out to be, Cat7 cables from a multitude of brands, including several Made in China would be more than adequate... If it can carry Gigabit Ethernet , it can carry Masterlink
I somewhat cringe at the idea of using 8-pin conductors (improperly called RJ-45) as Powerlink connector but it seems to work for some ... Could be my next project :)
While the original ML cable consisted of 9 conductors, one of these, the White-Bllue one was not used. Besides Beo recommends now Cat7 in lieu of the (expensive and difficult to find) ML cable
Here is a scheme I used to good results. I got it from a discussion in this very forum, I forgot the thread...😮
PAIR
Masterlink
Cat 6/7 STP
Pin on RJ-45
1
White/Orange
White/Orange
1
2
Orange
Orange
2
3
White/Green
White/Green
3
4
Blue
Blue
4
5
Pink
White/Blue
5
6
Green
Green
6
7
White/Red
White/Brown
7
8
Red
Brown
8
All Shields to
Shield/Screen of STP
Shield on RJ
I have used Cat 6 shielded cable to great results. I have a next project and for that I may use stranded CAT7 cable. much easier to work with solid-conductor Cat7 which is very, very stiff.
It would pay to implement a structured cabling system in a home. Structured cabling was never meant to only carry Ethernet. a real Structured Cabling system is a passive system meant to carry anything really, Analog and Digital signals of all sorts: Audio , Video, Controls, etc. Cat7 cable is particularly well suited to carry simultaneously various type of signals. It simply makes sense to use it with Mastelink and to be ready for the future Beonet.
The cables I have within the walls are both - shielded and not shielded. Depending of the timing when installed. For ML sound distribution tis is more than ok.
Heribert
For Masterlink, the most important thing is that both sides of a balanced signal are carried in the same twisted pair in the cable. If the pairs are split, I'm sure they cabling will pick up all kinds of interference from anything that happens to be nearby (in addition to internal crosstalk). In the chart misteUS posted above, this is done correctly.
The missing signal is Masterlink sense, and leaving it out apparently is no problem to most devices - but I'm sure there are some that won't like it left out.
Masterlink is just baseband audio and very slow (in comparison to any Ethernet standard) data. It'd work over barbed wire if the environment is kind enough...
B&O is very security conscious ... they give us PIN codes for our HiFi and the ability to tie it down with brabed wire so it can't be removed
Thank you guy, now I have all the data I need :)
Regarding brands of cable, then yes even chinese cable will most likely do the trick, however the specs on e.g. lapp is much higher and with the high cobber prices I dont trust the chinese to make cables up to standart, so I would strongly advise on buying German made cables.
