Hi
I have no idea about the German cables you mention but for the purpose at hands: Masterlink or even the future Beonet, whatever it pans out to be, Cat7 cables from a multitude of brands, including several Made in China would be more than adequate... If it can carry Gigabit Ethernet , it can carry Masterlink
I somewhat cringe at the idea of using 8-pin conductors (improperly called RJ-45) as Powerlink connector but it seems to work for some ... Could be my next project :)
While the original ML cable consisted of 9 conductors, one of these, the White-Bllue one was not used. Besides Beo recommends now Cat7 in lieu of the (expensive and difficult to find) ML cable
Here is a scheme I used to good results. I got it from a discussion in this very forum, I forgot the thread...😮
PAIR
Masterlink
Cat 6/7 STP
Pin on RJ-45
1
White/Orange
White/Orange
1
2
Orange
Orange
2
3
White/Green
White/Green
3
4
Blue
Blue
4
5
Pink
White/Blue
5
6
Green
Green
6
7
White/Red
White/Brown
7
8
Red
Brown
8
All Shields to
Shield/Screen of STP
Shield on RJ
I have used Cat 6 shielded cable to great results. I have a next project and for that I may use stranded CAT7 cable. much easier to work with solid-conductor Cat7 which is very, very stiff.
It would pay to implement a structured cabling system in a home. Structured cabling was never meant to only carry Ethernet. a real Structured Cabling system is a passive system meant to carry anything really, Analog and Digital signals of all sorts: Audio , Video, Controls, etc. Cat7 cable is particularly well suited to carry simultaneously various type of signals. It simply makes sense to use it with Mastelink and to be ready for the future Beonet.
