Hi Guys
I want to connect my bv8-40 and bs4 to a bs2000 in my kitchen, this requires about 30 meters of wire and a few holes drilled etc, so I would prefer to make this as futureproof as possible.
Cat7 I can put plugs on myself etc and the cable is quite cheap compared to masterlink cable. Can I use Cat7 and then from a masterlink junktion box simply put in a premade masterlink to masterlink cable to the source and to the bs2000?
Are there any guides etc? and any comments on if this is a good solution?
