I need to pass a BEO masterlink cable through my network installation in my home. The network is STP and I only need to patch the masterlink from a room to another. My question is, what leads should I use according to the technical specification found at beotech.co.uk (
Masterlink through STP (CATx) cable
Hej
Du skal bruge Grøn og G/hvid et par
Blå/hvid og Pink kortsluttes så der kun skal bruges en ledning
Blå i en ledning og i par sammen med pink
Orenge og O/hvid i par
Rød og R/hvid i par
Og meget vigtig det skal være skærmet Kabel
(med Par menes de to kabler der er snoet om hinanden)
Mvh
Hi
I have just had a Lexcom system installed which is basically Cat6 Cable.
I purchased LexCOM passive hubs witch join the masterlink together over Cat6.
I then purchased LexCOM powerlink and masterlink cables from my local B&O store which is a masterlink to RJ45 plug so i am sure these will work for you too if you are using Cat6 cable.
Andy
Hi Andy,
I also have the "LexCom" passive hub in my network installation and I know that you can buy the cables at the local store, but I need to the insert the cable from the network outlet into a conjuction box and I don't think that the lead colors matches the original colors used in a ordinary master link cable. Therefore it would be good to know what leads to use before I burn off my entire BEO-setup...
