Masterlink Question
I have been trying with little success to get all my B&O products linked correctly, I'm sure there used to be some software which helped with setup but I cant seem to find it.  I hope someone will be able to answer this for me before I drive myself up the wall :)
Room 1 (Living Room)
Oveture set as Master
Beogram connected to Aux
2x Beolab 8000
Room 2 (Kitchen)
BeoVision 6 (with DAB Radio)
2x BeoLab 4
Room 3 (TV Room)
BeoVision 6 (with Dolby 5.1 card)
Mac Mini Connected to PC (soon to be connected to digital IN)
2x BeoLab 1
2x Beolab 4000
All products are connected with a physical masterlink cable.
I would like to be able to stream the audio of the connected Mac Mini to all the rooms at the moment and the Record player from the Oveture.  The Beogram works in all rooms but not the output from the Mac Mini.
Unfortunately I can't connect the Record Player and the Mac Mini to the same source, is it possible to leave the overture set as master and access the audio of the Mac connected to the BeoVision upstairs?
Thanks in advance,
Nic
the latest version of the PCG (
Thanks,
I will take a look, one thing I am concerned about it says in the guide that PC can only be used for local source and not sent over masterlink?
thatlondon wrote:
the guide says that PC can only be used for local source and not sent over masterlink?
that is true, you really need to connect your Mac Mini via USB to a link box
you would also need the IR Eye to control the volume from your Beo4 remote
or get a     :-)
have you seen
Thanks,
What a pain in the backside, thanks for all your replies, it looks like my precious vinyl collection is still going to get some wear when I am downstairs then.
I was not too worried about being able to control the Mac as I could use iTunes Remote, but being able to stream music would have been nice, I will have to live without for the time being.
Thanks Again.
There is also Phillipe's new software (LinkPlayer) to replace BM-Link on the BeoPort
I suggest you take a look at his site as LinkPlayer is a superior product even though it is a beta test version
Cheers,
I will see if I can pick up a BeoPort second hand somewhere.  For the moment I have been reading that there is the possibility of connecting the audio of the mac to the scart socket and then using that as a link source.  I can't seem to find the right kind of adapter at the moment but I might give this a try.  Ideally the Beoport looks the best solution as I would like to use the TosLink in the Mac mini to get dolby 5.1 and a dirty hack would have me pulling cables in and out all the time.
It's a shame as there does not seem any easy way to connect an external audio source such as an iPod and then distribute the sound over masterlink.  I guess B & O like to sell their own products.
well there is the link at 189 euros
and super integration with a remote
