Master Link Gateway full integration solution - News!!
Does anyone know the price for this product ? I have a Lutron system and it works very well, but I am really disappointed since the Beo 5 needs to be pointed towards the sensor to make the light, curtains etc work. Keith told me that my 7-40 took the edge of my IR-signal and maybe this might be the solution ?
Keith, if you are reading this I have one more question since you told me that I would be able to control my Lutron system with my Beo 4, but I cant get it to work with the commands you helped me with ? If I press the commands you told me I just control my LC2s in the living room which is about 15 ft from my TV-room.
Best regards
Hans
The product is not yet released, so no price yet.
p.
For direct control of Lutron GRX with Beo4, it has to be a BO compatible model (GBO instead of GRX); either a control unit or a keypad.
With MLGateway, home automation commands will be received directly by the beolink products (BV7 in your case), relayed to MLGateway, who will in turn control the Lutron system via Ethernet/RS232.
Ah! 💡
Thanks, now i get it... that's cool!
Now more information about the product and a concept video is available on the their website:
Yeah,
very cool ! 😳
We can see the BeoVision 8-40 with the BL3 in the master bedroom (and the electronic curtain) ! 😕
Anyone have more information about the gateway and how it works and what home automation solution that is support now and if there are plan for supporting more home automation solutions.
I have an LK IHC home automation solution and it doesn't seams to be included in supported solutions. Anyone knows if there are any plans for integration with IHC.
Regards
ken
LK IHC is fully supported.
Do you know how it works. How does you connect the gateway to the IHC system and how do you add the gateway as a input and output devise in IHC visual?
Do you have any kind og manual describing this and the functionality you get avaliable in IHC visual?
Regards
Ken
