Hi Martin,
Sorry for brining up this embarrasing thread lol, but you are a legend from my understanding. 👍 A real magician! The Doctor of all things Bang & Olufsen, I really need your help Buddy. So let me explain exactly what has happened. I have just very recently brought this system which included a BeoMaster 7000, Beogram 7000 CD, Beocord 7000 Tape, a Beolink 5000 with a missing screen, a pair of Beolab Penta II and a Pair of RL 35-2 which cost me around 680 quid. When I finally got the system and tried it, I plugged in an Ipod connection into the Aux socket but could not select that function via the remote, so then I tried the Tape 2 Socket which also did not select. Then I tried the Phono socket, which did work. So thats how I run my Ipod connection. The whole lot does sound a little bit flat, I need to turn up the volume to around 24-38 to get a nice sound.
So I just started to enjoy the system and moved it all to my flat, because it was all at my parents house. Set it all up excluding the RL35-2 and was working fine. The CD player worked fine, and when the tape function was selected, the tape deck made a noise like the motor was working but the tape was not spinning. To which I thought I will fix this problem at a latter date. Some of my Mid-Range Speakers needed refoaming aswell which also would have been repaired at a later date.
So now to the flood!!!😡😡😡
I think the burst pipe was leaking for around 2 days, but it did not drip on to the system, but there was plenty of condensation in the room. The system was plugged in and on standby for the whole time up untill I discovered what had happened!!! So Me being a complete mug I turned it on and tried the system, it kind of worked but one of the speaker had a kind of interference/crackel type noise coming from it, that was the speaker that had water running under it, the rest did not 😡 So I played my Ipod through the Phono socket for a min then turned it all of via the remote. When the landlord came about half an hour latter, I tried the system again to show him the damage to the speaker. It would not turn on!!! I was shall I say very upset by now.😡 So I assummed that all it needed was drying out. So I arranged for removal of the system, which unfortunatly took about a week. Once I got it all back to my parents I set it all up, exactly how I had it in the flat, but now it has started to play up.
The speaker that had water running under it!!! Was the first noticable problem, one of the Bass drivers was distorting quite bad, but luckily I had brought some spares from Ebay, so I replaced the problematic Bass Driver in the water damaged speaker, which luckily solved that problem. Then all of a sudden the screen stopped working. 🙁 So I paniked and opened up the bottom of the Penta, did I know what I was doing, Hell No, 😮 so I just blasted a hair dryer at the circuit board at the bottom of the speaker, and low and behold after a little fiddling the screen just suddenly came back to life!! I was jumping for joy as I had already been eyeing up a replacement screen on ebay for around 40 quid. So my speakers are ok for now thank god, but I think a re-cap and re-foam is in order to get the best out of them, which I plan to do myself with some instruction from the guys here on the forum. Never done it before so any advice would be greatly apprieceiated for example what type of Cap's do I need etc? 👍
Now for the Beomaster, that worked ok when I got it home, then after a while, the Ipod connection stopped working through the Phono socket I tried to turn on via the brokenish remote. Nothing happened so then I tried to change the connectio now it only works through the tape connection, the CD still selects and works but nothing else, no Aux, no Tape 2, etc. Also I cannot store any setting like Bass, Treble etc. Plus because the Beolink 5000 is missing the screen I cannot determine if the remote is at fault or the system or both. I defineatly think that the system needs repairing and a service, I really don't want to bin it as I just brought it and it seems to kind of half works. So this is where I need your help my friend can you please take a look at my Beomaster if you have the time and tell me whats wrong with it and carry out any repairs if needed. You would be an absolute life saver if you did, as I am not having much luck recently.
The flat was a very new tenancy and had not even been decorated or furnished yet. So no insurance had been taken out. So I really am out of pocket if the System can not be repaired. I have a three month old son as well which costs me arm and a leg, but that is the only good thing in my life right now, and I wouldn't have it any other way. I love him just as much as my Bang & Olufsen. The flat also has two Avant Tvs in there but they seem to be ok, thank god, they do have there own issues, but that can wait. My main concern is getting the Audio part of my syste working. So there you have it , the whole story. I am really sorry for going on a bit, but I really wanted to explain everything properly so then you can get an understanding of my issues. YOU ARE THE MAN, so I have been told. I hope you can help me, and I hope you have all the information needed to proceed. Please don't hesitate to ask if there is anything I have left out that can help with your analisys.
Very Kind Regards one Depressed Nidul signing out 😮
Ps; Once agian I do apologise for going on a bit 😮
Pps; I am based in the UK and can be contacted on +44-(0)7538870940 😕
