The general question is : what should we buy so that we can listen to CD’s (musical classic and jazz mainly) from the sound of B&O.
Hello,
here's my take on this request.
If you want to hear the sound of B&O", you'd better benefit of the Emerge internal DAC.
This means that you would need to connect a CD player to the Emerge through its optical input.
Hereunder a (hopefully accurate and complete!) list of B&O CD systems / players equipped with digital out and few personal comments.
Disclaimer: B&O CD players have been discontinued many years ago, therefore the following options are 10+ years old as a minimum.
- Beosound 9000: a true classic, expensive if required to be serviced.
- Beocenter 2: nice but it is not an all-in-one solution, it is made of a main unit and a socket unit where all the connections are made. Personally I would prefer a single-box solution.
- Beogram CD7000: more traditional boxy design but still beautiful; a bit unpractical due to the very limited controls, unless the matching Beomaster is added to the set.
- Beogram CD6500: same as CD7000.
- Beogram CD5500: same as CD7000. This one is said to be one of the best sounding CD players ever made by B&O.
- Beogram CD4500: same as CD7000.
- Beogram CD3500: same as CD7000.
- Beogram CDX2: nice and not requiring extra parts but it is said to be not the most reliable player.
Another take and less risky solution might be to follow cklit's suggestion, getting a new 3rd party CD player with optical out.
Olivier
