jc wrote:
Returned from a weekend-off; the room is aprox 50 m2. Is the 80-s/90-s stacking system like a beomaster 6500 better in handling a larger beovox than my beocenter 9500 or isn't it that much of a difference. ( to make things easier I could change my current 9500 to a 6500 with for example a RL7000 beovox.) In the end it's all about soundquality to me.
Hi jc
The short answer is no.
The high-water mark for B&O amplifiers inside a Beomaster was probably the 8000 of the 1980s. After that the Beomaster 5500, 6500, 7000 and Beocenter 8000, 8500, 9000 and 9500 ranges were more geared around the Beolab speakers if you were looking for a bigger sound. Those amps are great with something like CX100s, but you can forget about them for serious listening with a big speaker like M70s or RL 7000s.
I get the feeling from your postings though that you prefer the looks of the stacking Beosystems or the Beocenter 9000 range. Unfortunately you can ask the question in as many different ways as you want, but the answer will always be that Beolab 5000, Beomaster 4000/4400 and Beomaster 6000 or 8000 are the best amps for big passive speakers without exception.
