M5 sound suddenly appears less boomy
mbolo01 wrote:
But why did they change the upper disc click sound for a so loud one ???
Agree! Super loud.
mbolo01 wrote:
I confirm it is less boomy after the upgrade, nicer sound now! But why did they change the upper disc click sound for a so loud one ???
I think it has to do with equalisation. The click is now both louder and brighter, but that counts for treble and mid range overall.
I think they gave a substantial part of the higher frequency range a significant notch upwards to match the bass.
Just noticed mine had more defined click with volume and less boomy.
Much much better sound
I got new software for my Beosound 1. And, same here, better sound less boomy.
Great B&O!!
Volume level has changed too. Mine´s default volume was 20, I had to reduce it to 17 to get the same perceived volume level than prior to the update.
I also find the volume increment quite big when using the M5 top disc
Not to derail this thread, but my BeoSound 2 has recently started having an issue where it will suddenly stop playing and be unavailable for a few minutes. I just checked and it has the new software.
Keep us posted.  Maybe start a new thread.  I see an upgrade is waiting for my BS2, but I'm now hesitant to follow through.
