M5 alarm Tunein problem
[View:https://archivedforum2.beoworld.org/members/ianpugh/default.aspx:300:0]I think you have a different app. There is only a Bang & Olufsen app available. I think there was a Beoplay app in the past but it is no longer available. At least not in the App Store or Google Play store.
The app I have has no radio option as per the screenshots below:(to follow in morning)
Strange that you do not have the radio option. Just looked at the app on both my iPhone and iPad and the option is there.
If you go to the configure menu for the M5, then content, then sources, then in local list, is Tune In checked as a selectable source in the list? Don’t know if that would make a difference, just a thought I had.
Also, what version of the app do you have? The app on my iPhone updated this morning to 2.9.
Hi again Razlaw,
And you're checking with the M5?
Kind regards,
Ian
Hi Razlaw,
Thanks for the help!
Yes, I do have TuneIn in the source list and it is selected. I see my app also updated this morning so I'll try it when I get home. Hopefully that may have fixed the problem.
KInd regards,
Ian
ianpugh wrote:
Hi again Razlaw,
Kind regards,
Ian
Yes, checking the M5.
Sadly the app update didn't do it. Still no radio option and still unable to choose radio as alarm in alarm settings on app. :(
I have an M3 arriving in a day or so - let's see if that one has it.
That is so strange. I keep looking at my app to see if I can find some setting that might resolve the problem but am not seeing anything else.
Have you tried to remove the M5 from your products in the app and add it back?
