Lutron Rania
Hi folks
I know that questions have been asked about light dimmers before so look away now if this subject provokes yawning, heavy limbs and fatigue.
My question is painfully simple and being a simple person, I am fumbling for an answer.
My questions: do all Lutron Rania dimmers respond to a Beo 4? Or is it only certain models/type of Rania dimmer that can be controlled by B&O?
Thank you for your help.
Comp
only the B&O Rania.The Beo5 can operate the normal Rania.
yes, I can confirm this also.
I have both in my living room : 1 x the B&O version and 1x the normal Rania IR. I wanted to have 2x the B&O version, but you can not set
them individually.
Spot on, thank you both very much.
Comp
I have been in touch with Lutron regarding this and they say that they will work with Smart remotes B+O remote but the Lutron codes will need entering!
Chris,
  Steve at sounds heavenly sells the lutron dimmers see his link at the bottom of the page
