lost remote for Beoplay V1. Q's re joystick Beo4 logitech harmony et al
Thank you so much for the excellent reply and advice.
I managed to switch it on with my old beo4. It wants the pincode. Can enter numbers but the centre go button doesnt enter so for now I'll wait for the navi Beo4  🙁
Is B&o no longer able to help with a master reset if I provide the serial number. The tv is legitimate but Im unable to reach the original owner.
Thanks again
That is a question, that I am not able to answer.
You should contact a B&O dealer in your area to see what can be done.
Mostly they can identify the unit via the serial number registred at B&O.
Good luck.
Got it working, The Navi remote is good and switched to mode 1.
But now I see it has ancient 2012 firmware. Unable to connect it via ethernet and no wifi antenna
Nor can I find a way to download it, or puc' for usb install.
Any firm advice on upgrading an old V1 to avoid freezing. I have seen odd posts with warnings but also mixed reports which is confusing.
Thanks again for all the help.
