I made some photos:
Open Beocord, I also took of the back panel but it isn't really necessary, since the tape unit has to be removed anyway.
To open the front, only losen the 4 screws on the top side, don't remove them.
Toren belt on the backside.
The small belt on the front was also lose.
Replaced one.
To remove the tape unit, you need to losen the upper mainboard and disconnect 3 cables in total.
It's a little bit tricky to get it in and out, but in the right angle it's no problem.
To get to the main belt, you need to remove the cover on the bottom side of the tape unit. It just covers it, nothing else comes lose.
Supplied with new belts. Since the thin one was toren, I had no idea how to wield this belt, but I figured it out.
Put everything back together and your Beocord is good to go 😁
