Lintronic ready for Beo5
Yes, we are BEO5 ready and our TT455-RT-238 is much more versatile then first anticipated.
BEO5 will be a nice add-on ... and vice versa ... not a mutual competitor 👍
TT455-RT-238 can receive triggers from:
- B&O Keyring, BL1000, BEO4, BEO5
- Bose Lifestyle system
- All NEC code based remote controls (Apple, for example)
- Relays, switches, contacts, PIR motion detectors, telephone relays, etc. etc.
- All types of X10 transmitters: Handheld, wall mounted, RF/IR, dusk/dawn sensors, etc.
We control ... welll, se our Triggers and Actions page .. you will be amazed. And these are just examples.
Furthermore, the TT455-RT-238 is a nice PC gateway allowing you to control audio/video devices ... also your B&O system ... via SMS, email, HomeAutomation, etc.
TT455-RT-238 is often used as man-machine-interface (MMI) controlling for example, projector On, input selection, light levels, curtains, down, lock door :o) Up to 32 actions in ONE macro.
Using an industrial 2-wire long range RS485 network, up to 32 pcs. TT455-RT-238 may communicate around the house. We are currently about to support PowerMax security system, allowing you to arm/disarm the house from your bedsite or control the lights all over the house or the curtains, etc. with the BEO4.
You can have different reactions in different rooms to the same trigger. Example: When it gets dark, close curtains in one room, turn on lights in fish tank in another room, etc.
When hitting AMEM button, turn off stereo in all the kids rooms, close the garage door, set outside light level to 5%, etc.
Controlling curtains by relays instead of IR is betting bigger and bigger.
I could go on and on ... but why not drop by and see for yourself.
Regards,
LinTronic, Michael Lindgaard
As Michael´s very full description says a superbly specified system which should complement any B&O system Beo5 or 4 and one we hope to handle ourselves in the near future.
A quick thanks to Michael too who has now put a link  to Beoworld from his main website, details of which you will find on our links page.
