Lintronic + Beo4 + Jung lighting
Hello there!
I have a Jung lighting system with RF remote control and I was wondering if I can control it with my Beo4 "LIGHT" 💡 button if I install the Lintronic system to convert the Beo4 signal into RF. But I look on the Lintronic site, Jung switches are not on the list of supported lighting system products.
Any positive (or negative) experiences with the aforementioned setup? Thanks!
Best regards,
Alexander
I would personally suggest that you should contact Linktronic for this.
They are very helpful and I'm sure that they could possibly help you on this issue.
Thanks for the suggestion, they were very helpful and quick-in-reply indeed. They confirmed that my setup is possible indeed.
Cheers,
Alexander
