Is there a way to connect a Lintronic unit to the control signal in the scart socket so you can control your non B&O equipment from a linkroom?
BEOfreak
BEOfreak
The best person to answer that is Michael at Lintronic who is very helpful. Check out his website.
cheers,
Kevin
Not sure about your question because it assumes that you want to run a long SCART cable from a link room which you should not do.
Lintronic can control a link room because it has an RS232 interface cable which can link units together.
As far as i understand, the Lintronic unit require a IR input signal (and then translate it to a non B&O IR signal). When I press DVD in a linkroom, the signal is transmittet via masterlink to my Avant (in the masteroom) and then to the Avants scart socket where it normaly will control a DVD (via the scart cable). I want to be able to control a non-B&O DVD/HDR from a linkroom. A solution could be a DVD-controller or One-remote, but the Lintronic unit is more flexible.
Best regards
BEOfreak
this could be a solution.
Hi Heinz,
I have looked at the oneremote solution, but I want it to be more flexible (I want to define which botten does what) like Lintronic.
Best regards
BEOfreak
Thanks Kevin, I'll try Michael directly.
Best regards
BEOfreak
