I have a couple of splitters which I could use.
In the past I tried to use them to share an aux socket for dual input (record deck and apple express) into the beosound 9000. I found that when both inputs were connected the sound level was much reduced and very flat/dull.
I assumed this was something to do with impendence to the signal input.
Might this be a problem in the scenario of using a din cable with i/o switched?
Alan
This is completely correct. Never use a splitter, which means splitting one output to two inputs, as a mixer (or merger) which means, mixing two outs to one input. outputs are low impedance and inputs are high impedance..but read yourself - here is an article that also offers a solution..
https://www.prosoundweb.com/why-not-wye/
Stefan
