jans wrote:
Hi Carsten
Intresting setup! Can you describe in more detail how your system looks like? Inassume your Beosound system feeds into,the WXC, which drives Beolabs?
How do you do volume Control? On the source systems (tv, B&O), or on the WXC?
Final question: don't you miss a Center speaker for Voice when using the tv?
Jan
Hi Jan - Here is my set-up:
Login to view image
My purpose with the WXC was:
- to allow optical connection to my Beolab speakers WITHOUT going through the Encore (as going through the Encore give Lip Sync problems),
- to be able to adjust the sound parameters (balance, bass, treble etc.)
- to give me AirPlay conncetivity.
- to allow use of TV without sending sound to the Beolabs. If I connect the optical from the TV directly to the Transmitter, then the Beolabs will always turn on, and the sound parameters could not be adjusted
Volume control: Once the level has been set on the WXC, I just use the TV remote to adjust level.You can btw set the WXC to just pass the sound through bypassing the WXC volume control.
Center speaker for voice. The SONY has two sound options; "TV Sound" that will allow use of TV speakers with the audio system. However this do require a bit of fiddeling with both TV volume and Beolab volume to get balance right. Second option is "Audio System" which will send sound ONLY to the Beolabs. When using this setting I can only adjust sound parameters on the audio system, not on the TV. Before I got the WXC this then meant a little flat sound in the Beolabs. When using the Beolab's I use them without TV sound, and for me it's OK with voices.
In a wired set-up I actually could connect both the Beolab speakers and Beolab Sound system to the WXC as it is able to "trigger" the Beolabs to turn on and off (with the proper cable). Thats at least what the Yamaha sales rep told me :-)
I hope above can answer you questions. If unclear just let me know :-)
