linking a beocenter 9300 (w. passive speakers) to a BV7 (w. active speakers) with a 1611 converter
Hello everybody,
I could not find the configuration file that supposedly shows all ways to combine B&O products. I tried to configure both the BV7 and the BC 9300 on option 1 (I am not even shre I managed that) but in any cas I got no sound. My objective is to hear on the loudspeakers of my stereo the sound inputed in the television by my computer. Any Idea how to achieve this?
My configuration is
Computer -> analog entry -> BV7 -> Master link cable -> Converter 1611 -> AUX cable -> Beocenter 9300 -> Beovox 4500
Many thanks in advance
François
If you have set your BC9300 to A.OPT 1 and the BV7 to V.OPT 1 - this should confirm both systems by a short flash of the standby light - and your computer is assigned as for example V.MEM just press AV - V.MEM and your BC9300 should be powered up, AUX input will be opened and you should hear the sound of your computer...
Stefan
did you use the config guide (available elsewhere on the site) i found it useful when setting up various small systems
salut
tony
Kenavo Tony!
Alas, I could not find it!
Kind regards
François
Hello François,
it's this one:
