Link room with passive speakers
Hi
I have a question for someone with technical knowledge.
If two Beovox speakers are to be installed, a Beolink passive is needed (with amplifier included), right? So far no problem. I also have one passive noname loudspeaker in a bathroom ceiling. I am told that this also could be used in the same zone as the two beovox speakers. This should mean that the all three speakers will play if you start the zone. Are there some method to be able to split the three speakers in two zones with just one Beolink passive? What I would like is to play the speaker in the bathroom without starting the two beovox speakers (or start the two beovox without the bathroom). It is not necessary to be able to have two different volume level in the two rooms.
Can this be solved without buying two BL passive?
Have a nice evening/morning
Clakke
Hi Clakke,
No chance.
You will need two BL Passover I'm afraid.
Best regards
Spiros
I think that you could solve this problem with a simple passive speaker switching box.
Connect the BeoLink Passive amp to a loudspeaker switch box and then connect your three loudspeakers to the switch box. Speakers A can be switched on whilst Speakers B are off or vice versa. I don't see a problem with this working. You just need to position the speaker switch box somewhere easily accesible to switch on whichever speakers you want to listen to.
Opman
Should be possible to connect two Extra Speaker Kits - MCL2A - to the BL passive. You will also need two IR receivers. Now you can control your main system from both zones.
Stefan
Opman
Hi
Thank you. This should work. It is a "rough" solution but will probably work.
Clakke
Stefan
Hi
This sounds most interesting. Could you develop a bit more please? What is a MCL2A?
Clakke
Look at the
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
kallasr wrote:
Look at the link (PDF)
Google search on: mcl handbook bang olufsen
Ralf
Hi
Forgot to thank you for your answers, so I do it now. I will read it when I have the time.
Have a nice evening
Clakke
