2nd post!! this is fun!
My link room speakers (BL4000) come on at a very high level when switched on , any way to change this?
thanks
thanks
Ah ! found the answer on the site! thanks
Hmm - how strange! I have been thinking a lot about this problem. In my livingroom I have a BM5 and BS5, hooked up via a BV7 (acting as audiomaster). In the dining area I have a pair of BL3 linked via a BeoLink Active module. The sound level is unfortunately quite high when turning the BL3s on. I tried to search the forum for the answer you found, but I was not successful in my quest... Does anyone have a hint on how I can find where to change this setting? I am still a novice in the B&O world of unlimited cusomized choices and settings... 😳
//Anniber
Try this....set the volume where you want it
then List until get to speaker, use left and right on Beo 4 to adjust balance
then
List on Beo 4 until get to A.Setup might have to add this function to the Beo 4, once there press go
List will then bring up bass treble and loudness which can be adjusted and finally a store function.
