Link problems
Hi everybody, I have a BV 7-40, a BV 7-32 and a older MX 4002 that I would like to connect by Master Link.
I have connected all devices together and BV 7-40 will be the "master" and I would like the other ones to be links since I have a Dreambox, a X-box and some more devices connected to the BV 7-40 that would be nice to distribute.
Earlier I have connected the BV 7-40 and the MX 4002 with Masterlink and eveything worked perfect. Now, for example, I cant get the DTV-mode to work with the 7-32 and the MX 4002.
 I have tried different options ( V-OPT ) but it will not work.
The antenna cable goes from the BV 7-40 to the BV 7-32 and then to the MX 4002.
Can anyone give me some suggestions to a solution to this problem ?
Best regards
Hans
Anybody?
I think you are missing the RF amplifier...
Is the DTV tuner only in the BV7-40?
If you mean the decoder ( my Dreambox ) so yes, it is only connected to the 7-40. I also know the fact that if i would like to distribute the pure TV-signal I will need the RF-amplifier since the 7-40 doesnt let thorugh the antenna signal as for example the Avant.
But I cant understand how I earlier ( before i got the 7-32 ) could watch DTV on the MX 4002 ?
Have you set the BV-7 32 to the right Option ? (5 or 6, I believe)
Do you mean you can get analogue TV on the MX OK but just not the digital TV signal? Have you checked the link frequency between the 32" and the MX is OK? Would the link frequency need to be set the same as the master? Have you tried with the 32" on and off?....
JB
Sounds like you have connected your MX 4002 to the RF out of the BV7-32 (?).
Stefan
Yes, that is correct. The MX 4002 is connected to the RF out of the BV 7-32. The BV 7-32 RF in is connected to the BV 7-40s RF out.
I dont understand is why i cant get a SAT picture from the 7-40 on the screen of the 7-32 ?
Regards
Hans
I think the problem might be that you need to "split" the cable after leaving the BV7-40 rather than daisy-chaining. So from BV7-40 RF out you then go to a RF splitter and then from that seperate cables to the BV7-32 and the MX4002.
Also I thought with the BV7 you needed the link-amplifier in the set-up (unlike Avant/BV3) but as you had it working before with the BV7-MX4002 I guess not. Have a look at this thread for more info.
That is exactly what I meant - thanks dylan.
 Stefan
