Link Beovision 6-22 and 7-40
Carolpa wrote:
How are the option set?
BV7 option 2? or
BS3000 option 0? or
BV6 option 6? or
BV7 option 1 (i think)
BS3000 option 1
BV6 option 6
Andreas wrote:
BV7 option 2? or
BS3000 option 0? or
BV6 option 6? or
BS3000 option 1
BV6 option 6
Link between audiomaster and linkroom works, link between videomaster and linkroom  does not.
I`d check video option setting of your BV7, should be V.OPT 1 or 2.
Stefan
stefan wrote:
Andreas wrote:
BV7 option 2? or
BS3000 option 0? or
BV6 option 6? or
BS3000 option 1
BV6 option 6
Stefan
Do you have speakers connected directly to your BS3000? if YES then BS3000 option 1 and BV7 option 1 ; if NO BS3000 option 0, BV7 option 2
I have now tried almost everything.
still no picture on the BV6
I can list up my complete setup
BV7 with BL7.2
BV3000 with BL6000
BV6
BV7 : option 1
BS3000 option  1
BV6 option 6
BV7 with BL7.2
BV3000 with BL6000
BV6
BV7 : option 1
BS3000 option  1
BV6 option 6
Test: what happens when you give an AV-DVD command to the BS3000? And what when you send the AV-CD command to the BV7?
BV7 with BL7.2
BV3000 with BL6000
BV6
BV7 : option 1
BS3000 option  1
BV6 option 6
I think I tried both AV-DVD and AV-CD command, I get DVD-sound on the BS3000 and CD-Sound on the BV7. I will have to check it once more, not at the facilities until next week.
I found a broken wire on the MasterLink to the BV7, now everything works as intended.
Thank you all for your help.
I found a broken wire on the MasterLink to the BV7, now everything works as intended.Thank you all for your help and tips.
