Line input Beolab 3- Bladelius
Hi.
What kind of input signal will the BL 3 accept when set to line mode?
The thing is that I wounder if I can connect the Bladelius Mimer directly to my beolabs and control
them from the Bladelius player.
http://www.bladelius.com/products/bladelius/mimer/
Bladelius have the following connections:
  • 2 pc Toslink input
  • 2 pc spdif input
  • 1 pc analog input
  • 2 pc USB
  • 1 USB togo
  • Analog input
  • Headphone out
  • Pre out
  • Ethernet
  • Wifi
  • Supports 32bit/384kh
  • Coax digital out.
Atle
You will need these cables if your planning on hooking them up via line.
http://www.ebay.co.uk/itm/RCA-Plugs-Bang-Olufsen-B-O-BeoLab-3-BeoLab-9-Speakers-Pair-4-Metres-/131139644955?pt=UK_Sound_Vision_Compact_Shelf_Stereos&hash=item1e88882e1b
I'm not sure if Steve at sounds heavenly does this type i haven't come across it myself, but if i was intending to purchase beolabs 3 to use on a pre-amp that's the cables i would be looking at
Thank you for the link.
It seems like those cables should work, without any more hardware.  🙂
Atle
