Lighting control question
I have a security system that uses Z WAVE devices. Through it I can control lights, security system, and video cameras from my iPhone and iPad. There is a remote available for the system to control the lights without accessing the App. It appears it is the standard remote that can be purchased to control the lights directly. I also have some Philips Hue lights.Is there anyway to gain control of either or both sets of lights with a Beo 4? I am thinking there is not, but I certainly could be wrong.Thanks!
Technically yes but the better question is does it involve the investment of your/your dealer's time?
There are ZWave/RS232 Interfaces that can be programmed as ML Gateway custom 232 drivers. It would be A LOT of work for VERY little payoff. Almost better to just change your lighting system to RadioRA2.
Thank you very much. I sounds like too much work for the amount of benefit. Again, many thanks.
