Lightcontroller in Bepvision 7-40 MKIII
Is there a way to switch light on and off, and even dimming lights with the Beovision 7-40 MKIII. If the answer is yes, how many lightsources can it contro, and can it do it in different rooms through b&o ir-eye? What about curtains and a projectorscreen that can go up and down?
Isn't that controlled by the remote control, instead of the TV?
That's just what I was thinking!
Andy T.
Only some 2 way products had this possibility.
Well think you are thinking about beoliving where there is a special beoliving box connected to the TV that handle timing in turning lights on, off, dim, screens, doors (like in struer) and so on...
Beo 5 also can do a simple version of it 🙂
OR
look at lintronic's homepage thy have made a complete system with X10
What exactly is this beoliving box, and what does the cinema module of the bv7, bs3?
Are the specs available?
Does it support more than 2 modes: cinema moon, and normal mood?
