I want to control my lights with my BEO4.
What is the best way to control my 3 dimmers (2 Halogen and 1 normal Bulb) ? All three are mounted in a wall spot grouped together.
Thanx
Thanx
Do a search of this site or the wider web. This has been much discussed here!
go to this link
This Light-Manager is specially made for remote controls from Bang
& Olufsen. It contains an original B&O IR receiver module which
is plasma-safe. The control is done with the light layer which is
present on almost any B&O remote control (e.g. Beo 1000, Beo 4 and
Beo 5). Up to 100 light scenes can be programmed. Also light scenes or
general control tasks can be assigned to any button. The Light-Manager
has an integrated real time clock. The configuration is done via the PC
software Lightman-Studio (available in our download area for free).
Even complex light scenes can be created easily by drag & drop.
Supported
actuators: InterTechno series (434 MHz) and FS20 series (868 MHz).
Compatible with all B&O remote controls with have the light layer.
Plasma-safe. Windows PC required
