Posted July 25, 2023 at 18:39 GMT
I don’t know German law specifically, but UK law (EU Law) would be for an immediate replacement of the LG Panel. If the panel was 50 to 70% into its warranty period, then a repair would be “reasonable” to all parties.
Further, by your B&O Dealer giving you a “Metz” screen and not another LG screen, he is denying you the inherent features of using the B&Oflagship soundbar with a fully integrated panel screen.
You should, in no uncertain terms demand an immediate a replacement LG screen (either as a full replacement, or as a temporary screen while yours is repaired) and that to include any demonstration screens on display in the Dealers shop.
You should tell the Dealer you are very unhappy with the current treatment buying such a high value consumer product from him to be treated this way. You could buy an LG G3 from Amazon Prime, have it for 8weeks, find a fault, send it back and receive a full refund and buy another - delivered in 2days tops.
Finally, I would make the Dealer aware that if he does not sort this out to your satisfaction by the end of the week, you will be informing Denmark (CEO) directly. Email is on the B&O website.
Stand your ground, insist on proper remedy, make a noise if you have to. This is totally 100% unacceptable
