The funny thing was when I initially set up stage and c9 and mini q the beoremote 1 can control the sky q box via Cec but I must have messed around with the settings because the next day became slow and gradually unresponsive......I cannot repeat this since😮No, not in the slightest. Someone said on here that the Sky Q box is deliberately non-operational from another remote. Sky designed it this way. The regular Sky box is, but not the Q. Perplexingly, Sky Q does show on the LG as a controllable device, but the LG magic remote does nothing when trying to control it.
LG GX + Stage is here, some initial feedback
Does anyone know how to setup the LG + Stage + BeoRemote so that the Sky Q box turns on automatically when you turn the TV on? Never works. I always have to find the Sky remote and turn the Sky box on first.
If I turn the LG on, from the LG or BeoRemote, the Sky Q box remains off. Doesn't seem to trigger it on.
Hi everyone,
Quick thank you to the contributors of this thread, in particular Moxxey. Stage and GX 65 installed yesterday. Had a custom built tv bench made for it.
Really happy with how it all turned out, the room is a small secondary tv room and quite squared off so the sound works perfectly. Re-watched Inception last night with wife and it was awesome, I am sure it will be mainly used by the kids for Peppa pig in the future 😁....
Only issue I have had is the stage does not always come on with the TV and I have to re-add it in the LG settings. Need to play around with this. It also took a few attempts to set it up with the beo app in the first place.
Now waiting for the remote and H95´s to arrive and this room is done.
Cheers,
Ammier
That looks good Ammier! Very clean. Inspiring actually! :-)
J.
My compliments Ammier.
Curious to know if menu setting "General -> Additional Settings -> Quick Start+" is turned on or off by default; and if default is On, then whether turning this feature off makes any difference? (Your multiple initial setup attempts indicate something else is going on, but I would like to know if the TV resetting all external ports by powering down fully is a panacea.)Only issue I have had is the stage does not always come on with the TV and I have to re-add it in the LG settings. Need to play around with this. It also took a few attempts to set it up with the beo app in the first place.
@Johan @RS4326 Thanks a lot! I take no credit, wife designed the bench and our awesome carpenter here Norway built it and installed the tv with me.
@trackbeo the Quick start is automatically on for first time use. Ive now turned on the earc which was off, just to mess around. Ill keep you posted but it does seem like the tv resets the ports when off. It doesn't happen every time though...
Thanks Ammier. I have a GX 55" + Stage and a GX 65" + Stage, but the 65" isn't yet in-use. I'm planning to shift furniture around end of October as the 65" is in "the snug" which is a better room for the winter months. Sadly, due to solid walls, I've not been able to hide the cables in the walls as easily as you and planning a move in the next 6 months, so my view is I'll setup properly after moving!
Looks amazing though! Love my setup. If you want a wall-mounted TV, you can't go wrong with the GX and Stage combo.
Thanks! Completely agree, its a great setup! After a couple of nights of movies I think its money well spent and the whole package wasn't that expensive comparatively speaking. We are in a new build here in Norway, moved in last year, there is about a 5 cm gap behind the plaster wall before you get to the insulation so the cable management was quite straight forward.
