Hello BeoWorld members,
One of my LC2 Light Controller is broken-down.
Does anybody has a circuit diagramm or service manual?
Thank you for your feedback.
Klaus
Klaus
I also need a diagram, but I suspect it is locked away within the B&O vaults somewhere, never to see the light of day again!
Maybe a letter to B&O themselves but make sure it is sort of, 'authorative' in some way!
These units are relatively simple though, and I am sure if you describe the symptoms there is a chance the fault could be located...
Google translation
Forget the programmed number of blackout ( 🤔 ):
EEPROM IC3 defect
No operation with touch, IR ok:
Silver layer on top is bad. Repair it or replace IR cover
Google translation
EEPROM IC3 defect
Blackout is not really the correct translation. More correctly it should be Forget the programmed number when no power (or power off).
Klaus
Klause,
The Service Manual is now available for download...
Hello Keith,
Great!
Thanks a lot
Klaus
Where did that come from?! Nice one!!
Are there any more manuals waiting in the wings to surface Keith?
