LC2 appears to be toast - recommendations for 3rd party equivalents ?
After failure of 1 of my two LC2's (dead even after changing the  fuse) I'm on the lookout for a 3rd party equivalent. I don't want to have to program it by computer - I'm aiming for the simplicity of the Lc2, wire it in and the B&O remote switches it on & off. Thats all !
Previous searches seem to have recommended Lutron /Lintronic / JBMedia. Can I ask for current thoughts on these as Lc2 alternatives - specifically bearing in mind I just want to wire it into single lamps (no in wall / big box config).
Any advice appreciated !!
Good question. I have found this bosscom unit to be quite close to original in form and function. Maybe someone has better / different suggestions?
link
Why the apparent reluctance to publish any prices? Bizarre!
You can buy them on Ebay - pricy!
http://cgi.ebay.co.uk/Bang-Olufsen-BossDim-wall-light-dimmer-Beo-4-5-remote-/220784604696?pt=LH_DefaultDomain_3&hash=item3367c9b618#ht_784wt_972
http://cgi.ebay.co.uk/Bang-Olufsen-BossDim-light-dimmer-Beo-remote-LC2-dim-/220796183181?pt=LH_DefaultDomain_3&hash=item33687a628d#ht_1170wt_972
What is the experience in using these when 1. Using a plasma TV in the vicinity and 2. How directional are they - do you have to point the remote in their direction to get them to work?
Another option is to repair the broken LC2's. In most cases the problem is caused by 2 capacitors, it's an easy fix!
Please post details of this 'easy fix'.
Yes - please tell of the fix. If it's a visit to the local electrical repair shop for standard parts to be changed then I'll give it a go. Cheers
I think this is the trade/retailer site - they don't want to publish prices so that you and I don't see what they actually sell them to the retailers for. Mind you, perhaps we could all club together and become a reseller ourselves (!)
I tried a product called Innovus RAOne Smartdimmer. It works just like a LC2, responding to Beolink 1000, Beo4 etc. Only thing is it emits a soft, high-pitched whine when on. Only available in 240V.
Leo
There is a 220uf and 22uf capacitor although I cannot remember what the voltage ratings are - they are on the lower PCB part of the 5v supply.
Repalcements should be 105 degree low esr and a good make. Worth a shot for what they cost!
