I am running a beomedia mainly for N.Radio and N.Music. Foto and web is also ok, but not roccket science. I am not happy at all using the BeoPlayer to "organise", store and play mp3 files and I am wondering whether I can utilise iTunes installed on tmy beomedia instead.
I was surfing quite intensively within BeoWorld forum getting the impression that there are some out there using their iPod touch as 2-way-remote control to select and play mp3 files in all linked rooms. If have seen statements saying, that together with the Beo 4 remote and the iPod touch running appleremote or RemoteBuddy it seems possible to select V.MEM (via Beo 4) and using the iPod the select the album to play.
I have the following question:
Is it possible to install iTunes on the Beomedia directly (after going to the desktop usig the Service Menu) and to "connect" the N.Music function of beomedia to play iTunes instead of Beoplayer? If so, what exactly is to be done? I only know how to get to the desktop of my Beomedia, having windows XP available to install iTunes, but that´s it. I have no clue what to be done on all the Beo-Settings....
If it is not possible to run iTunes directly on the beomedia: How to link an appleTV or any PC to the Beo master link system, so it is possible to chose V.MEM and listen to mp3 files in all linked rooms? As I do not have any clue on Beo Settings and my local dealer does not want to give any hint, I would need a "cookbook"-type of explanation..
Thanks in advance to all guru´s out there!
pfannera
