I have an Beovision 4-42 with Beosystem 2 in my office.
Is there a way to connect the Apple tV 2 to this System or is the only way Apple TV 1?
kind regards, Newbie
You can get an HDMI/Composite converter and use one of the scart sockets (theyre on amazon about £20 and work fine) - the PUC should work with Apple TV, if not chose the learn remote command on Apple TV and choose another STB for apple tv to learn
Maybe the way to do it is to hook it up the same way a PC would be attached to the system - only the audio (optical out from ATV) goes into beosystem and you cable the ATV directly to the second input on the monitor. Not sure if your monitor has a DVI input or not, if you scour the internet you can even find a HDMI input blade for those panasonic displays.
Hi all Beoworlders!
I have the same Beosystem 2, and as far as I know, my BV4 display has some kind of connection / port under it. (DVI I guess).
Can someone please tell me exactly what kind of cables and/or adapters I need to make my Apple TV (gen. 2 or 3 as far as I know) to work with it? Both picture and sound would be Nice!
(For streaming music and movies and so on from my iPhone and iPad).
Thank you for all help 🙂
I use this to my BV7-32 and a BV4-50 at office
But you only get stereosound!
Thank you Mr. Anderson.
Do you have a name or recomended manufacture for this strange looking item? Works for both picture AND sound?
Any other cables needed?
What version of the BS2?
Actually I don't know.
The sticker with the serialnumber is long gone...
