Is lifstyle Av. Secure To buy on line?
Thanks for the good information
Hello Toubro,
Do you know how can i see the milage that a bv9 have? And how many years the bv9 plasma can be used?
Pepso wrote:
Hello Toubro,
I never bothered checking the milage on mine, so I'm afraid I don't know how to. I think you have to enter som kind of service menu.
Pepso wrote:
Hello Toubro,
Pepso, I'm not sure if it will be 100% the same for BV9, but here is how you access 'service counter' on a BV5 tv - I'm guessing it is probably the same, or very similar process :
Put TV to 'Stand-By'
Press 'TV' on Beo4
Press 'MENU' then select 'SET UP'
Press 'GO'
then press '0', '0', GO quickly  (press zero twice and then GO quickly)
This then gives you access to the service counters of the TV, you can see how many hours TV has been in use so far, how many times TV has been switched on/off so far etc...etc.
How many years can BV9 be used..? Again, I'm not sure about the BV9's screen - all I know is what Lee has told me previously regarding BV5 and that is that the panasonic screens used in BV5's were expected to have a life expectancy of 'at least 60,000 hours'.
My BV5 is now in it's 9th year and has just passed the 10,000 hour mark. This is considered a 'low to medium' usage tv and i'm hoping it will go on and on for many more years/hours. Thus far it's perfect, without a single scratch or blemish and still looking like it came out of the factory (in DENMARK of course 😎) just yesterday 🤒
The only TV I would swop it for would be a BV9 in fact 🙂
Regards,
Hi bentleyman,
Thanks for the useful information. In fact is the same, I tried on my bv7 32" and it works. I'm gona try on bv9 that I won't to buy. On a B&o store a salesman told me that in 2002 the bv4 plasma have a expect time of normal use of 17 years .
