In 2011 my B&O Avant32 died after just 8 years. It was replaced with a BeoVision 7-4 mrk IV. Just the other day the display became faulty. The problem is, that B&O cannot repair the display. You have to buy a second hand TV.
I'm not sure I agree with this either. 8 years is significant for the life of most electronic products used daily, from any manufacturer. If you think about it, your TV is switched on/off most days and gets a lot of use over this period. Panels - which make up the highest proportion of the cost of the TV itself - only have a finite lifespan and remember B&O has to rely on panel manufacturers and these manufacturers change their specs almost yearly. Unless B&O stockpiles old components and leaves them to gather dust in their warehouse, what else can they do? And even if you wanted to swap out a panel on an 8-year-old B&O, it would be so cost-ineffective it *would* be cheaper to buy a second hand replacement.
If someone said to be 8 years ago: "you can rent this B&O TV for £75/month for 8 years" I'd have gone with that option. I don't think anyone can get angry that their TV has only lasted them 8 years and after 8 years can't always be fixed.
