Is Beosound Core discontinued?
At one B&O sale-shop in sweden it says that the Beosound Core is discontinued. Is this right?
Have someone heard anything about this?
Best Regards
I haven’t heard anything about this.
However, that would mean that there must be something else to replace it - it is needed for the BS Shape!
Just checked... I cannot see anything saying that.
Wasn’t the Core updated at some point and subsequently given a new Part Number? I seem to remember reading that the Core underwent some minor hardware changes which warranted a new P/N. Could just be the old P/N having been declared as “Discontinued?”
B&O did an price increase on the Core, from 800 to 900€. I think they don’t do that on an discontinued product.
That’s what I was concerned about the longevity of the core as I was deciding whether to move from the beolabs with essence to core or to the level/Mozart
Core was updated at some point with a different part number to include the ability to use an IR eye. That's it. Otherwise, unchanged throughout its life, as far as I understand.
I heard that it will be a new version!
Maybe Mozart compatible? But now that Multiroom and Mozart can play nicely, I'm not sure why a big change would be required.
What other changes might they make to Core? :)
Core is not listed in the list of supported products…? https://press.bang-olufsen.com/d/gKpSDxqk8eyT/news#/january-2022/bang-olufsen-celebrates-40-years-of-multiroom-with-new-software-that-connects-past-with-present-and-future-products
