Hi
I am trying to use the Thinking Cleaner for Roomba driver with the BeoLink Gateway but I cant get it to connect. I have added the driver and input the IP address but can't get it to connect, the system connection status bar at the bottom stays blue as it says that it is offline. I can see that the driver was coded by a member of our user community, is it a matter that the driver does not work with the new Roomba's? Any advise would be much appreciated.
Regards
Huw
