Hi
Our TV is moving and will be located about 30m from the sky box, blu ray etc. The ir sender cables B&O supply are only 5m, and I don't really want to dig he walls out to run longer ones (apart from ML, which is already in the right spot)
Everything else is going over cat 5, but has anyone succesfully used cat 5 to send the ir signal back to devices connected via the PUC?
