IR receiver cable pin question
I need to make a IR receiver cable for a BeoLink Passive unit; but can't find any information regarding the pin layout for the DIN7. Any one able to point in the right direction?
You may find the following helpful
Or this one:
Raeuber wrote:
Or this one:
link
/Räuber
Exactly what I was looking for, thanks Räuber!
Hi Keith & Räuber ,
Thanks for both replies; as I'm having an IR kit from B&O I assume that Räuber's suggestion is the way to go.
Keith what you're suggesting with the schematics;  to be used together with the B&O IR kit?
My image is from the circuit diagram which shows the pin connections which is the same connections as shown in Räuber's image.
The wiring to the Control is shown in the user manual
