IR Eye
Hi, its been a while.
Like the new forum and thanks to all for the effort involved.
My IR Eye on a on a beo link active kit no longer responds. It flashes a light when a button on the remote is pressed though it no longer activates? Any ideas?
cheers and thanks, beoaus
Hello beoaus
Have you solved the problem as I have the same issue and am looking for a solution.
Must not be the ir-eye - please check your MasterLink connection(s) as well.
The Beolink Active is wired into the wall. I turned off the circuit breaker to reset it.
Thanks.
All the same, there probably is a ML-junctionbox somewhere.
I am not saying that it is faulty, but it is worth checking it.
How many other ML-components do you have in the setup?
