I just got a Beovision 4 with Beosystem 2 and now need to screw the cable to the IR eye.
In the setup manual is a different IR eye with 8 screws, I got one with only 5 screws.
The IR cable has only green-brown-yellow, so what to do?
Yellow = 5V
Green = IR Data
Brown = Sense .....or is it black (?) = ground
Hope this helps
Stefan
Hi
I just made it few feews ago and took a picture of the wiring, it works so it should help you.
OK this is what I did:
So since there are only 3 wires in the BS2-IR-cable: yellow, green, and brown, I only connected these three as shown in the Beolink Passive manual.
This caused some problems, the Beosystem 2 was changing the channels sometimes accidentaly, very strange.
changed the wires now so it matches the picture that matbkk posted, hope it will solve that problems (for the moment it does, but you never know...)
