Forgive my ignorance on this subject: Is it the US AppleTV that is different firmware, or the Beo?
Surely it is not just the geography 😕
Stefan
OK, so it's maybe not a geographical issue then. Could it be old versus new BV7-software?
No, I haven't tested another AppleTV but this one works perfectly with the AppleRemote.
How do you pair a Beo4 with the AppleTV when the AppleTV does not respond at all to Beo4?
Haven't tried to take digital images of the IR-sender 😕
/M
Actually, Stefan may be on to something.
If you have paired your remote to the AppleTV, then it won't recognize IR-signals from other units.
Go into the settings menu and unpair the remote (if paired).
Thanx anyway !
There is no reason why thw beo4 shouldn't work. I guess that as mentioned it is to do with the Apple remote still being paired to your ATV.
There is loads of info on pairing and unpairing remotes on the the web, and I would really look nto this before slating B&O software too much.
If the STB setup is correct you should at least see the light on the ATV flash when you hit buttons on the Beo4. If you do and yet it isn't working, I would definataley look at the pairing issue
What do you need to control AppleTV with the Beo4 in the US? Please post explicit details.
Thanks,
Dario
I have a BV8, I selected Ipod Remote - made sure ATV is unpaired - and it works like a charm.
I think you have to have a current STB software, it may even be that one works and a later one doesn't. Beocare confirmed for my BV8 that it can control the ATV. It might be beneficial if you contact them and ask them which version would support that. They can find out from product management, it took them a bit though.
JK
