Introduction BeoVision Harmony
Beozip wrote:
Cool, the software has clearly advanced! Still no footage of "Audio Mode"? I guess setup is the same for Stage + C9?
Curious when the BeoLiving-implementation is ready and what it looks like on screen!
So, the big question is will you in the future when 8K and eventually 16K screens are more available (and affordable) be possible to upgrade the current LG 4K screen with an 8k or 16k screen only, i.e. retain the B&O speakers/stand/controller but replace the screen?
Is the 4k driver components in the B&O part of the unit, or in the LG screen? I would assume in the screen, but with B&O you never know, they prefer to sell you a complete new unit rather than upgrade.
yes this will be possible, the B&O bit strips some of the audio out and does it's magic from there. In a few months 8k will be available. 16k is a bit dreamy though, next big step is 10k but that will be 2 years or so on LG's part for the first ones to appear.
I have some up here, the sound is super impressive! https://youtu.be/-OJzER1GKW8
My dealer said yes. The screen is basically on a VESA mount connected to the motorised stand. The only thing is that all the settings for the B&O stuff (speaker groups, roles, WISA,etc) are managed by an LG WebOS App which will be available only on certain models (the C9 as it stands now). In the future they will be able to limit which TV sets can be used with the Harmony by selectively enabling access to the app.
Is the TV connected to the speaker with an HDMI cable? If so, what are the actually usable HDMI ports, 3 or 4?
All information is available here:
Thank....must be quite new.
You may have noticed that there is a port for a Stand....which in this case is not in use.
This might indicate that the same platform ‘could’ be used for another configuration of a speakers part and an LG-tv.....maybe sometime.
Yes, we need both a vertical and rotational movement at the same time! :)
