Introduction BeoVision Harmony
@ Michael
Add to that,- on smaller panel sizes the problems you list will increase due to the smaller active area. There was properly some cleaver reasoning behind choosing the 55 inch as the starting size.
link
Emil Jensen wrote:
<a href="https://beta.photobucket.com/u/emilos88/p/616a9fa3-5cca-471b-b7c2-6c29342a0169" target="_blank"> <img src="https://hosting.photobucket.com/images/ab181/emilos88/0/616a9fa3-5cca-471b-b7c2-6c29342a0169-original.png?width=1920&height=1080&fit=bounds" border="0" alt="Skærmbillede 2019-06-25 kl. 19.47.51"/> </a>
Interesting the price point is 10% below one big store. So the question is: Where would you want the warranty for the OLED to be issued?
It’s also without stand, remote and speakers. The warranty should come from B&O if you buy the TV from them. I remember B&O saying that a screen could also be bought separately but that’s another story.
My wife and I went to see the Harmony launch last night and were reminded what makes B&O special. Having the demonstration and background story about Valeur harking back to the original “wheelbarrow” tv made it all make sense. All except the sheer scale of the Harmony!
The BV Harmony isn’t released yet.
How will the price of a stock C9 be in October (when the Harmony will be in the shops) - probably not like in your screenshot.
Apart from that - it is weird that a specified pricelist is already released by now - why?
Hallo Michael,
The TV is with Stand, remote and speakers, it is the same C9 as you can buy in other shops.
So yes the price is cheaper than there common stores, but as Millemissen points out, lets see in October.
Regarding the sound Karel,
I was looking up the specs of Harmony and saw that they are 450W and the eclipse is also 450W
The speakers on the harmony look very tiny and not near as big as the ones on the eclipse.
Would you say, if you have heard an eclipse,is a harmony better or?
To me it seems all of the space of the butterfly effect of the harmony speakers is taken up by plastic rather than actual speakers.
Happy to hear your thoughts as you have heard it.
M
the harmony isn't tuned yet. the speakers are mostly the same. tweeter and full ranges are the same. the mid range is the one from the bl50 and the two underneath are the same a s in the eclipse.
So it should sound better probably, but nobody has heard the final tuning yet.
