Interesting new multiroom document from B&O
I have found this new document on the B&O support website:
https://support.bang-olufsen.com/hc/en-us/articles/4411586315537-Which-sources-are-available-in-a-Beolink-Multiroom-setup-
It looks like the pre-Mozart speakers will also get B&O-radio 🙂.
Best regards
Dyssegaard
Nice find! Thanks for sharing.
It looks like the pre-Mozart speakers will also get B&O-radio . Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40 , AppleTV 4 . Home office: Beoplay M5. Kitchen: Beoplay M5 . Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Indeed exciting! Is there a list what products have spotifyconnect built-in? What about M3 and BS1?
If I understand the table at the link correctly, then all connected speakers should have Spotify Connect (since the latest sw update).
Best regards
Dyssegaard
Here is the current list:
Beosound Essence 2nd Gen
Beoplay A9 2nd Gen
Beoplay A6
Beosound 35
Beosound 1 1st Gen
Beosound 2 1st Gen
Beoplay M5
Beosound Core
Beosound Shape
Beovision Eclipse Soundcenter
Beoplay M3
Beosound 1 2nd Gen
Beosound 1 2nd Gen with Google Assistant built-in
Beosound 2 2nd Gen
Beosound 2 2nd Gen with Google Assistant built-in
Beoplay A9 3rd Gen
Beoplay A9 4th Gen
Beoplay A9 4th Gen with Google Assistant built-in
Beosound Edge
Beovision Harmony
Beosound Stage
Beovision Contour
Beovision Eclipse Soundcenter 2nd Gen
Beosound Balance
Beosound Balance with Google Assistant built-in
Beosound Level
Beosound Level with Google Assistant built-in
Beosound Emerge
Beosound Emerge with Google Assistant built-in
Beolab 28
Thanks for sharing.
"Line-in and Bluetooth cannot be distributed from products with Google Assistant built-in"
I know Miki has mentioned this in recent podcasts, but seeing it in writing.....another strong reason not to have any speakers with GA built in!
To be fair, this has been public on the support site for a long time :)
Thanks D and C.
This is quite good. Seems i’ll eventually switch from deezer to spotify then.
Has someone tried whether this also allows to distribute music that i activate via GVA (using spotify)?
Does this mean ML sources on the Beolink NL/ML are no longer supported? Or am I misreading this?
Sandyb wrote:
Thanks for sharing.
Crap... This is a real stab in the back to those who purchased GVA Emerge/Level/Balance without knowing that would have affected - in the future - the capability to distribute in multiroom line-in and Bluetooth sources.
