Dyssegaard
Indeed exciting! Is there a list what products have spotifyconnect built-in? What about M3 and BS1?I have found this new document on the B&O support website: https://support.bang-olufsen.com/hc/en-us/articles/4411586315537-Which-sources-are-available-in-a-Beolink-Multiroom-setup- It looks like the pre-Mozart speakers will also get B&O-radio . Best regards - Dyssegaard Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40 , AppleTV 4 . Home office: Beoplay M5. Kitchen: Beoplay M5 . Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
If I understand the table at the link correctly, then all connected speakers should have Spotify Connect (since the latest sw update).Indeed exciting! Is there a list what products have spotifyconnect built-in? What about M3 and BS1?
Here is the current list:
| Beosound Essence 2nd Gen |
| Beoplay A9 2nd Gen |
| Beoplay A6 |
| Beosound 35 |
| Beosound 1 1st Gen |
| Beosound 2 1st Gen |
| Beoplay M5 |
| Beosound Core |
| Beosound Shape |
| Beovision Eclipse Soundcenter |
| Beoplay M3 |
| Beosound 1 2nd Gen |
| Beosound 1 2nd Gen with Google Assistant built-in |
| Beosound 2 2nd Gen |
| Beosound 2 2nd Gen with Google Assistant built-in |
| Beoplay A9 3rd Gen |
| Beoplay A9 4th Gen |
| Beoplay A9 4th Gen with Google Assistant built-in |
| Beosound Edge |
| Beovision Harmony |
| Beosound Stage |
| Beovision Contour |
| Beovision Eclipse Soundcenter 2nd Gen |
| Beosound Balance |
| Beosound Balance with Google Assistant built-in |
| Beosound Level |
| Beosound Level with Google Assistant built-in |
| Beosound Emerge |
| Beosound Emerge with Google Assistant built-in |
| Beolab 28 |
Thanks for sharing.
"Line-in and Bluetooth cannot be distributed from products with Google Assistant built-in"
I know Miki has mentioned this in recent podcasts, but seeing it in writing.....another strong reason not to have any speakers with GA built in!
To be fair, this has been public on the support site for a long time :)
Does this mean ML sources on the Beolink NL/ML are no longer supported? Or am I misreading this?
Thanks for sharing.
Crap... This is a real stab in the back to those who purchased GVA Emerge/Level/Balance without knowing that would have affected - in the future - the capability to distribute in multiroom line-in and Bluetooth sources.
