I have a perfectly working ML system and with the BeoLink Converter NL/ML I should be possible to integrate the NL network with the ML network and vice versa. So I want the best of both integrated.
Here's an example of the visual feedback on my iPad via BLGW:
I have a question: If you try this with the BeoLink2 App - do you still see the covers / Content (visual feedback) of your BeoSound5?
Thanks for a short answer, because I go crazy, while mine does not show anything...
Best regards
Doc Leisure
BeoLink is still to much Beta, so no visual feedback from BeoSound 5 and you problably know already, software is not B&O's strongest selling point.
That`s exactly what i think - create a linkstation for the kitchen - set BLC to A.Slave with BL4000s connected to BLC instead of BS5. Set BS5 to A.OPT 0, BLC to OPT 2. Now you should be able to control all ML devices with BL4000 sound in that zone, and you should be able to control the NL-BV connected to BLC again with sound on BL4000s (?).
NB: If you set your BS5 to A.OPT 0 , it will turn on the BV9 Beolabs, when you control BS5 directly.
BTW: BM5 has a second video output (DVI) for a BV. Did you try to connect it to the Horizon?
Stefan
...If you connect speakers to the NL Convertor then you set this up as an audio slave and then it should work with synchronised sound throughout the house.
Stuart
unfortunately it won`t be in sync with ML devices...:(
Stefan
Only if you connect speakers to the NL convertor.unfortunately it won`t be in sync with ML devices...:( Stefan
Stefan
That`s what we talk about...
Stefan
@DocLeisure, @wv02447, Does the latest version of the BeoLink 2 application fix the visual feedback for the BeoMaster5 on you setup?
