Integration BeoLink Converter NL/ML and BV Horizon
I have a BeoVision Horizon 40", with the latest firmware update, connected via NL to a BeoLink NL/ML converter to the rest of my ML network.
For my installation are 2 things important:
1. I want to distribute the sound of the Horizon to the audio master (BeoSound 5) both are in the same room
2. I want to distribute the sound of audio master (BeoSound 5), which are CD and Radio to the Horizon, again both are in the same room
I have tried many settings of the BLC NL/ML, but I can't get it to work, who can help me with the correct settings?
I have attached an image of my complete system and screen shots of the BLC settings menu's.
Your help will be appreciated very much.
Hi!
I am not an expert on BLC, but try with something like this:
App Settings:
  - Friendly name: BeoSound 5
  - Product icon: BeoSound 5
  - Product controlled by Apps: ML AudioMaster
MasterLink:
  - ML enabled: checked!
  - ML role: Video Master
Sources visible on ML:
  - You should use some VIDEO sources as "ML Source" and map them to your TV sources.
Experience mapped to NL:
  - You should be able to select CD and Radio after you changed the ML role.
Best.-
Sorry no luck with these settings either, anybody else who has more experience with the BLC NL/ML?
try this setup. works well with my comparable combo (ML audio source, NL-TV)
Turn everything off.
Switch on Slave equipment first. Then BS5. Then the Horizon.
It should work.
I have a BLC working perfectly.
I`m also a newbie to BLC NL/ML. I just read the manual and got my first BLC a few days ago. But as I can see, a setting with a ML role as audio- or videomaster can`t work, because you have already a BV9 master and a BS5 master.
And there are some points, that I don`t understand with your setup.
- you have a BS5 in A.OPT 1 set to audiomaster, but no Beolabs connected...? can`t work - or did mean A.OPT 0?
- You have a full cinema setup in your livingroom and an additional BL passive in L.OPT 5?  may result in conflicts with ir commands...?
- Your ir setting is set to OPT 4 - why?
- are you using the BLC with an ir eye?
- Can you elobarate a bit more, what doesn`t work?
Stefan
Hi Stefan
There where a few minor errors in the picture of my setup, below you find the correct setup. In principle I have a perfectly working ML system. Just recently I added the BLC NL/ML converter with no speakers attached and the BeoVision Horizon.
All I want is distribute the sound of the Horizon to the BeoLab 4000's, which are connected to BeoSound 5 and both are in the same room.
Also I want to the sound of the BeoSound 5 distributed to the Horizon and if possible also the interface displayed on the screen of the Horizon. All these things were promised by B&O when the Horizon was introduced months ago.
Not an expert by any means and this is a complicated setup.
First problem you have is to define if you want a NL setup or a ML setup? I don't think you can have both i.e a master-master.
From your schematic, it is not clear where the NLML converter sits?
My initial view is to connect the Horizon (NL) to the converter and use it as virtual ML linked product. This however may not give you control of the BS5 through the Horizon.
You could make the BS5 ML to converter to Horizon and run it through the NL system, with a spiced ML to the rest of the ML system. Problem here may be the control.
Im thinking the only way to fully control the system is that all products have their own NLML converter on a N L network. But that is a very costly excercise. Maybe your Dealer can help on the config?
First of all
I have the new BLGW, which gives me of course visual feedback, on my iPad but it would also be nice to have visual feedback on the screen of the Horizon. This is what integration is all about and what B&O differs from the rest. According to B&O visual feedback of BeoSound should be possible on NL video products, only I don't have any visual feedback of ML sources on my NL video source at the moment.
Here's an example of the visual feedback on my iPad via BLGW:
